HI, In the middle of a long print last night , my extruder stopped extruding but the printer continued the motions. So my question is,
Can I back up and start the print where the print stopped? Would save my 8 hours of printing if I could?
Yep, you definitely would, otherwise the printer would home right away(G28) and ruin your print. You could go into the Scripts tab of your process and change the starting Gcode though.dennisjm wrote:You'd have to modify your start code as well I imagine. Want to make sure your start routing doesn't run the print heads through the print or something like that.
Have you tried it yet? I'm curious if this turns out for you.
