Update - Resolved
When someone said it worked fine for them I tried to do it again and it worked fine for me as well
As of now I am assuming I mistakenly clicked "continuous" (multi process slice) in 4.1.1 and not in 4.0.1 because when I do that I got the "bad result" but it worked fine when I correctly selected Sequential.
I am still getting bad slices for vase mode.
either z seams that should not be their OR flat out ignoring proper vase mode operations all together
factor file attached. 2 identical models different sections (heights) for a multi part print. sequential print 1 vase mode then 2 vase mode
4.1.1 broken retracts and moves between the two models ignoring sequential instruction 4.0.1 works fine.
