Request: z-lift only over top layer
Posted: Sat Jul 05, 2014 12:50 am
by jsc
I normally run with z-lift set at zero, but this does on occasion cause visible drag marks. It would be nice to have an option to have z-lift occur on retraction only when the next travel move is going to occur over any topmost surface.
Re: Request: z-lift only over top layer
Posted: Tue Jul 08, 2014 5:06 pm
by magnatag
I believe you can just create a 2nd process that will be responsible for the top layers only. There you can enable the z lift.
Posted: Wed Jul 09, 2014 7:43 am
by jsc
You can if you're making a box. Not for a more complex object with many "top" layers at different layers.
Posted: Fri Jul 11, 2014 2:36 pm
by ashleywebster
You can still do it with separate processes, you will just need a bunch of them. But I agree that it would be finicky and I think S3D needs a better way of managing processes. I want to be able to duplicate, clone, and drag-and-drop processes like layers in Photoshop. E.g. Clone a process, lock all of it's properties to the process below but override property D.
