dennisjm
2.1.1 SIGSEGV
Try to preview attached gcode file = sigsegv for me every time.
crash.gcode
(248.85 KiB) Downloaded 236 times
On OSX 10.9
KeyboardWarrior
Re: 2.1.1 SIGSEGV
dennisjm wrote:Try to preview attached gcode file = sigsegv for me every time.
crash.gcode
On OSX 10.9
Opened it in text editor, MakerWare generated Gcode.
TenKOhms
Re: 2.1.1 SIGSEGV
I opened it up in the text editor as well...
here is the fixed version, I replaced all the A's in the file with E, and added semi-colon's before the comments on each line... what did you use to generate this poorly made G-Code?
crash.gcode
(248.39 KiB) Downloaded 189 times
dennisjm
Re: 2.1.1 SIGSEGV
Tis true, it's Makerbot generated code (from their latest version 3.2). I was just loading into S3D to check the much better preview window and some print statistics.
