Problems with 4.1, now reverting to 4.00
Posted: Thu Dec 27, 2018 9:20 am
by dotty
The new version cannot generate the GCode for my print. Luckily I had the older version because it works.
Attached is the file so you can figure out what's causing 4.1 to get stuck.
Re: Problems with 4.1, now reverting to 4.00
Posted: Thu Dec 27, 2018 1:24 pm
by S3D-Alex
We were able to slice this in 4.1 successfully. Can you please post the Factory File for this issue?
Posted: Thu Dec 27, 2018 2:18 pm
Slices for me as well in v4.1
Posted: Thu Jan 17, 2019 3:49 pm
by dotty
Rotate is using -90 for x like this:
Does it still work?
Posted: Fri Jan 18, 2019 4:15 am
by mroek
Slices fine for me in 4.1.1 after rotating -90 in X.
Posted: Fri Jan 18, 2019 9:26 pm
by dotty
Ok, I couldn't when it was rotated but could when it wasn't.
Attached is the factory file from 4.0
Posted: Sat Jan 19, 2019 6:05 am
by mroek
Your factory file does't slice for me either. S3D just appears to hang at "Finding overhangs" while keeping the CPU busy at 100%. Pressing cancel doesn't work, and if S3D is closed (by pressing the X in the upper right hand corner), the window disappears as if it closes, but S3D leaves a process running, so to actually end it you need to kill the process.
