DaveA
Problem deleting profiles
I just noticed an issue trying to clean up some obsolete profiles. I had a bunch of profiles:
AnycubicDeltaLinearPLus
AnycubicDeltaLinearPLus - Test 1
AnycubicDeltaLinearPLus - Test 2
AnycubicDeltaLinearPLus - Test 3
AnycubicDeltaLinearPLus - Test 4
AnycubicDeltaLinearPLus - Test 5
As I was removing the test versions I noticed that the AnycubicDeltaLinearPLus profile had also been deleted. I've been playing with this and it seems to be dependent on whether there is white space in the name.
I just tried this on 4.1.1 and the problem is still there.
Re: Problem deleting profiles
Thanks for your bug report. Can you please outline the sequence of steps you follow to reproduce this issue? What's exactly required to cause the issue I'll forward your feedback to our developers after testing myself to verify the issue.
