Multiple Machine Types
Posted: Thu Jan 03, 2019 9:07 am
I have 3 different makes of printer and every time I use the configuration assistant to change the printer type in Simplify3D it starts with a new profile. I then select a saved profile but I have to delete the generic profile that Simplify3D started with after using the configuration assistant. I think it would be so much better if when you use the configuration assistant to change the printer type it should prompt you to either load a saved profile from your list or use the generic profile for that printer type.
