Amidatti
Connected machine, no response
When I open machine control I get this in the communication panel:
Attempting connection at \\.\COM29...
READ: ánP|$.HF'JpOn6ëH
READ: J%È1ÈhÀoN]L4'á\iäMxv~q^~‹HO
READ: J%P<H^Ð~ÈZnómó7—ˆKæ'já^ƒ;7jOÌ|—^ˆ=gJ‚%'
READ: „{ˆ]áM ±YP|kX·.lë|4]ˆxñ
READ: „J€xñ³HsH6FñJ„J%îJ/H^ˆIhZŽ
READ: :&(^Ì}ù$p|
READ: ^HJÄJˆYŽ
READ: ':&é]ÙZfñ
READ: „Z„Jˆ%^ˆ*'ék^>H]ùZˆKqaK0».aKk!«.aJ„jÀJˆ!HJÀJˆx±{]‹{6¡om_?9Â6}ë6ÀO6«}«6[Ä&>³K7&³K{&~óK&ÿóJ„z‚J`ˆ(ŽJj'ˆ(ŽJWŽ
READ: '
READ: ƒm!
Connected to machine!
SENT: T0
SENT: M105
Though Simplify says the printer is connected, the jog controls are not functional and the printer doesn't return temperature data. No other functions are responsive either. Where do I go from here to troubleshoot? Any thoughts on this are greatly appreciated.
I tested this with versions 3.1.1 and 4.1.1 of Simplify3D. My printer is a Taz 5 with version 1.1.9.28 of Marlin. The printer is communicates properly with the Lulzbot edition of Cura.
Taz5test.factory
(114.79 KiB) Downloaded 129 times
S3D-Alex
Re: Connected machine, no response
The odd characters in the Communication Log indicate a mismatch in the Baud Rate settings. I believe Lulzbot changed this with their most recent Firmware update. Please switch to 250000 from 115200. Please let me know if this does not fix the issue.
frichard7
I have run into the same problem, and yes the fix is changing the Baud rate to 250000. Just like the other user, I had just updated the firmware.
