Recalling an existing G code .
Posted: Tue Jan 08, 2019 1:52 pm
Hello , I have been using Simplify 3D for a few months now its an incredible slicer program ..
Now I have started using flexible materials in the last few weeks and just started using a different one from what I have been using before .
I did have to change the Process settings quite a bit to get the new material to work and had incredible success with it , I had to go back to my other flexible and noticed the print quality was awful ,, I went through all the checks to make sure the printer was in good shape ,, I did a full clean out of the old material to make sure it was not causing a problem , It came down to a setting I must have altered and cant find my original set up ..
Now when I go through the last of G codes I have used I can find one from a few days ago that printed just perfect , when I upload it is in preview mode , I exit preview mode to look at the process settings and it just shows the existing settings that I currently have .
Is there a way to look at my settings I used when I set up the original print ??
