Dual Extrusion Wizard
Posted: Mon Jan 14, 2019 12:50 pm
by Umpa
So I have designed 2 .stl files that when opened up in S3D one at a time align perfectly, I open the dual printing wizard and the objects break apart and re-align as separate items.
Is this correct, and how do I stop this from happening?
TIA
Ump..
Re: Dual Extrusion Wizard
Posted: Mon Jan 14, 2019 1:41 pm
by Umpa
I might have sussed it.
First thing I did was to export the stl files individually from within S3D. That made the alignment (origin) a little better after throwing the dual print wizard switch. Not perfect - but at least both objects remained on the build plate now.
Then I ungrouped the objects, aligned them how I wanted and then grouped them again, This time they stayed put.
This wizard seems to be a little hit and miss tbh,
Posted: Mon Jan 14, 2019 5:11 pm
by S3D-Chris
If the models import correctly aligned, you need to uncheck the Group and Align Models option of the Dual Extrusion Wizard. To move your models as a set without adjusting the alignment you may group the models after running the wizard.
