IDEX Standby Temperature
Posted: Sat Jan 19, 2019 12:20 am
by bakshk
Hey Guys this is my first post, I built an IDEX 3d printer, I would like to know how to setup standby temperature for T0 and TI. I am using Duetwifi and everything works fine with Cura. In cura when T0 is printing T1 is on standby temperature 175 deg and part cooling fan is off, same thing happen when T1 is printing. I have the part cooling fan working correct, I just need to get the standby temperature working. I would really like to use simpliy 3d for this printer.
Thank you.
Re: IDEX Standby Temperature
Posted: Sat Jan 26, 2019 9:19 am
by WalterL
I'm also missing the Stand By Temperature in Simplify. The setting of 0° for the inactive hotend doesn't work with Sigma printers (50° does!).
Regards, Walter
Posted: Mon Jan 28, 2019 4:56 pm
by S3D-Jake
If you're not printing at all with that head, I'd suggest setting to 0 and turning off wait for stabilization for that tool head's temperature controller.
If you want to manually add in some scripted temperature changes, there are scripting areas for the tool change. More details on tool change scripting can be found here.
