Explorer71
Simplify3D and SketchUp doesn't work
I am new to Simpify3D. I just spent a few hours making a model in SketchUp. I exported it as an .obj file. When I try to import it into Simplify3D I get junk. What am I doing wrong???
TenKOhms
Re: Simplify3D and SketchUp doesn't work
Mind sharing the OBJ file so other people can try it out?
as 10 said, you would need to post up the model so we can look at it but sketchup is not a solid modeler. its a surface modeler and is know for exporting bad models. its not the best software by any means for 3d printing.
KeyboardWarrior
Explorer71 wrote:I am new to Simpify3D. I just spent a few hours making a model in SketchUp. I exported it as an .obj file. When I try to import it into Simplify3D I get junk. What am I doing wrong???
I believe you can export an STL if you use this extension: https://extensions.sketchup.com/en/content/sketchup-stl
Markus
Same experience with me but using replicator G the object is ok.
model.stl
(1.43 MiB) Downloaded 365 times
KeyboardWarrior
Markus wrote:Same experience with me but using replicator G the object is ok.
Downloaded attachment, was able to get it up and working using Flip Surface Orientation under the repair tab.
http://www.simplify3d.com/support/tutor ... sh-errors/
Teejay187
To avoid having to flip the model in S3D, you can just select the whole model and select "Reverse Faces" and then export it from SketchUp
