Support from the bottom
Posted: Thu Jan 24, 2019 10:15 am
by pashaUSA
What setting needs to be changed in the the process to generate support from the bottom of the model?
Check the image. Arrow shows where I want support to be, but software does not generate it.
Re: Support from the bottom
Posted: Thu Jan 24, 2019 10:22 am
by wirlybird
You might try changing/lowering the support pillar resolution and see.
Also you can increase the support infill percent.
Posted: Thu Jan 24, 2019 10:55 am
by pashaUSA
Infill % already set to high number
Here are my settings.
PS: If I try this part with Cura Support is generated from the bottom for the part.
Posted: Thu Jan 24, 2019 11:41 am
by wirlybird
Zero out inflation and horizontal offset to see what happens.
Posted: Thu Jan 24, 2019 5:45 pm
by pashaUSA
nope, that doesn't do it.
Posted: Thu Jan 24, 2019 10:49 pm
by ViperZ
The support for caves has only overflowed.
The overflowing segment does not have an effect in a print quality.
It is not necessary to care.
