Faurholdt
Change layer direction on bottom layer
Sat Feb 16, 2019 1:59 pm
Hello
I want to change the angle on the bottom layer to 45 degree lines instead of 90 degree lines
How is this done? Thanks.
It's shown in the attached picture :shock:
gearsawe
Re: Change layer direction on bottom layer
Fri Feb 22, 2019 1:19 pm
Is this a raft layer, support layer, interior fill or exterior fill? they can all be be changed in each of there designated area. Look at infill and support tabs.
Fri Feb 22, 2019 6:32 pm
The infill showing in the screen print looks very much like the bottom layer of the printed part.
The "External Infill Angle" on the Infill tab has its first (or only) value set to either zero or 90. Changing the value to 45 will give you what you desire.
Faurholdt
Sun Feb 24, 2019 6:46 am
Thank you for the replies. It is sorted out now. Time to print :P
