STL Orientation on Import
Posted: Wed Feb 20, 2019 12:58 pm
by guitartoys
I'm really stuck here, and I'm sure this is something simple. I'm using Fusion 360. I have my preferences set to Z Up.
But when I export the STL files, and then import them into S3D, I have to flip them -90 degrees in the X-Axis. Normally not a problem, but I'm trying to do a dual head print, and when flipping the X-Axis individually, the 2 models then don't line up.
Is there any way to have S3D import the STL already oriented with Z-Up.
I'm dealing with a step file in fusion, and don't have normal geometries for me to try to work with.
Thanks.
Michael
Re: STL Orientation on Import
Posted: Wed Feb 20, 2019 1:11 pm
by wirlybird
My exports of native Fusion files to STL work fine when coming into S3D so my guess is that the orientation in the step may be the problem.
I have seen files brought into Fusion that looked like they were the right side up but did go into a slicer with a different orientation.
Posted: Wed Feb 20, 2019 3:20 pm
by tonyno
Try Tools, Options, Models tab, and add an Import Action (rotate).
Posted: Wed Feb 20, 2019 3:22 pm
by S3D-Jake
If you can't resolve the issue by changing your design settings in Fusion 360 you can always try using an import action from the Tools > Options > Model options menu. Your options there are scale, translate and rotate!
https://www.youtube.com/watch?v=E8ytvwfCn5g
