How to find extrusion speed
Posted: Tue Feb 26, 2019 12:43 pm
by kwangwoo
Hello.
I just started to use the 3D printer, and I have something that I can't understand.
I would like to know the extrusion speed, but I can't figure out.
If I set the default printing speed at 60 mm/s, what is the extruder speed?
(nozzle diameter : 1mm, manual extrusion width : 1mm)
Thanks!
Re: How to find extrusion speed
Posted: Mon Mar 04, 2019 3:47 pm
by jkmajcen
Assuming you are using S3D, just pick the appropriate printer profile which should get you close. Select the appropriate material profile (PLA, ABS, etc) for the filament you're using and print. Fine tune extrusion rate from there under the Extrude tab.
