Delata robot machine definition
Posted: Sun Mar 03, 2019 11:45 am
by Math51
Hello,
I use Simplify3D with my Micro Delta Rework from eMotion-Tech.
This printer is a delta printer with a build volume of 150mm diameter and 200mm height.
I downloaded the Simplify3D process profil provided by eMotion-Tech for the Micro Delta Rework.
And I was very surprised by the Machine definition setting :
.................................X-Axis..........Y-Axis...........Z-Axis
Build Volume.........110mm........110mm........180mm
Origin Offset..........55mm..........55mm..........0mm
Homing dir.............Center.........Center..........Max
I design a 150mm cylinder that I import in Simplify3D in order to test the diameter : this cylinder fill perfectly the build volume modeled in Simplify3D :
So I don't understand why, for a build volume with a diameter of 150mm, you have to define X-Axis and Y-Axis to 110mm ?
If I had to configure the printer in Simplify3D myself, I would have set this setting (as I have done in Repetier-Host or CURA) :
Build Volume.........150mm........150mm........200mm
Origin Offset..........75mm..........75mm..........0mm
And I try this settings in Simplify3D... but the build volume modeled in Simplify3D becomes wider than the real printer build volume (checked with 150mm cylinder).
So, I realy don't understand how the Machine Definition Setting works in Simplify3D : could anyone help me ?
Thank a lot !
Mathieu
Re: Delata robot machine definition
Posted: Wed Mar 06, 2019 8:40 am
by ziever
110mm is dimension of biggest square that can fit into 150 ish build platform circle - confusing but its true :D
Posted: Mon Mar 11, 2019 12:04 pm
by Math51
Hello,
Thanks for your answer !
What is confusing is how you define the bed size for a delta printer in Simplify3D : using the square inscribed in the circle of the bed.
In Cura (the previous slicer that I have used before Simplify3D), there is also the X and Y parameter to define for a Delta Printer, but you directly enter the diameter in X and Y.
Thanks !
Math
Posted: Mon Mar 11, 2019 3:12 pm
The definition of the bed size is not the only difference in settings between slicer software. Each producer has their own way of doing things, and there's no "standard" for producers to follow like there is for say video recorders.
If everything worked exactly the same, how boring life would be!
