Hi Everyone, Is there a way to turn on a dry run on SD3?
Thanks
Under the temperature tab, for heated build platform and primary extruder controllers, de-selectHoly1 wrote:That is when the print starts without the hot end heating up and extruder does not extrude. It goes through motions without printing. You can see if you model will fit the bed properly, it's good for oversized models. I have a delta machine that can print outside the areas in some spots.
