Custom G-Code on Pause
Posted: Tue Jul 29, 2014 12:01 pm
by theray
Hi guys,
sometimes i make multicolor print (with only one extruder) usually i pause the print and change filament but i need the extruder come back in home position while doing it else the print get **** off. Also during a normal print the extruder have to lift at least 5mm for safe print. Is possible to add custom g-code on print so people can handle the pause correctly?
Re: Custom G-Code on Pause
Posted: Fri Aug 01, 2014 4:25 pm
by KeyboardWarrior
What kind of printer are you using and what exactly would you like this G-code to do? You might be able to do this through a macro.
