Problems with brims around supports
Posted: Sat Mar 16, 2019 10:13 pm
I can't seem to get brims to stick to supports, for some reason brims are underextruded. But only brims and occasionally the first layers of support towers.
This makes them very prone to get knocked over:
This is a CR-10S running MarlinFW 1.1.9 and 25 point mesh bed leveling. I've checked and double checked the bed leveling, the E speed, and the flow rate for wall thickness. This never happens to me with Cura (but cura loves to leave support spaghetti, which then gets stuck on the nozzle, deposited, hardens, and gets bumped). The S3D supports are nice and clean, just really fragile since I can get brims to stick to them.
I'm using the suggested 50% "underspeed" for the initial layer(s).
I'm using Hatchbox PLA in 1.75, using a stock 0.4mm nozzle. I've made sure the start script enables mesh leveling in case it has been disabled:
Maybe if it printed slower? But I can't find any speed adjustment for the brim...
I'm at a loss how to make S3D manage this
I've attached an export of the profile used since there are a gazillion settings.
Code: Select all
G28 ; home all axes
M420 S1 ; Enable mesh leveling
G1 Z5 F3000 ; lift
G1 X5 Y10 F1500 ; move to prime
G1 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 Y80 E10 F600 ; prime nozzle
G1 Y100 F5000 ; quick wipeI'm at a loss how to make S3D manage this
