scaling issue with internal \ external dimentions
Posted: Mon Mar 18, 2019 7:06 am
by 33phil9
Hi! I need help with simplify3d scaling… I am trying to print figure as below… In the model external size (marked with red) is 29.214mm and internal circle is 6.4 mm.
Once printed in 100% scale external is 28.9 and internal is 5.0 ☹ once I adjust scale to 101,08 external prints with tiny difference, but internal is still very small. To print internal in right size I need to use 128% scale ☹ but it drives external size far away…
Which settings should I consider to be changed?
Many thanks!
Re: scaling issue with internal \ external dimentions
Posted: Mon Mar 18, 2019 7:22 am
by wirlybird
Small holes are going to do this. No real way around it. Just the nature of the process.
If you can't enlarge them a bit in the drawing for the model then drilling/reaming them out is the only other real choice.
As far as the outer dimension being off it isn't much which can also be anticipated but could be that you are under extruding some or it is a mechanical issue.
You might see about doing some calibrations using a 20mm calibration cube. Lots of articles about it around. May help.
What printer and material?
Posted: Tue Mar 19, 2019 6:51 am
by 33phil9
cube prints fine... external diameters are good. it is something with slicer and holes. i guess it is a buggy algorithm....
with test i have figured out that horizontal compensation -0.25 mm worked with my 101,08 scale.. however that ratio brought down external size
in my particular case i can live with that, but it is very and very strange...
Posted: Fri Mar 22, 2019 1:24 am
by MicroVoxel
Try playing with extrusion multipliers and horizontal size compensation. I find
this model to be very helpful.
