is Delta size setup working correctly?
Posted: Fri Mar 22, 2019 11:33 pm
Is this normal? My delta (Anytcubic Predator) can print a 370mm diamter circle but only a 260x260mm square. Ok, fine.
In Simplify3D, I set it for delta and 370mm. I then dropped in a 370mm part, and it only filled a small fraction of the build plate. I had to change Simplify to a 260mm build area to show the 370mm.
That doesn't seem like how it should work.
See enclosed images - the part is 360mm diameter:
