HOLD Shift to Select Models?
Posted: Thu Jul 31, 2014 1:24 am
by Milestone85
Is there a Hold shift to select all or something similar, any way to select a bunch (but not all ) of models at once ?
Re: HOLD Shift to Select Models?
Posted: Sat Aug 02, 2014 12:55 am
by Umpa
what from the file menu when you import your STL or after when its on the build platform ?
Posted: Sun Aug 03, 2014 7:14 am
by AndersE
middle mouse button move one object, shift + middle button moves all objects. But no selection of objects as i can see.
Even if one object is deselected in the object list it moves.
Or did you mean multiload objects from within s3d? No..
But weird thing is you can drag object from import window to s3d, but no multiselect.
But you can multiload objects by dragging several objects from explorer into s3d.
Posted: Sun Sep 07, 2014 6:44 pm
by Milestone85
Yeah just trying to move models around on the bed, like to be able to CTRL + Click to select each model, I guess the select & move all isnt so bad i didnt know that one.
