Import size is wrong.
Posted: Sun Mar 24, 2019 5:05 pm
I have made several designs in fusion 360. This one seems to be with problem. It is my 2nd one importing to Simplify3D and the 1st worked fine. Fusion designed in inches so conversion is a problem. Seems to import VERY small and the size shows the right numbers but as MM and not inches. Did not convert to MM upon import. Went to Fusion 360 again and exported to see if it got things wrong. Same thing. Is there anyway to make simplify3D recognize the measurement correctly? Trying to get this right before the new 3D printer gets here.
