problem with internal thickness zero walls
Posted: Thu Mar 28, 2019 12:39 am
by Diego2019
Hello everyone, I hope you can help me, and I really did not find this thread, so I do it.
I usually use solidworks to design, and as for solid models I have no problems, but it turns out that for some designs, I find it useful to design with surfaces, and in them the wall is 0mm thick. With this I control the thickness of the wall of the piece simply changing the nozle.
the problem is when there are internal walls with zero thickness that does not recognize them directly, I have seen in designs this technique, for example in airplanes printed in 3d that has no problem in printing these walls.
What can be wrong?
Re: problem with internal thickness zero walls
Posted: Sun Mar 31, 2019 11:16 am
by gearsawe
S3D needs a closed contour to fill in with material. it will not work with what you are trying to do. It will not put a bead on the edge of the surface. you will have to "thicken" the surfaces in SolidWorks. the only reason you see something with the cylinder is it is a closed contour. This would be more of a feature request. To print on the edge of lines and contours. not sure if there is a slicer out there that would do this.
Posted: Sun Mar 31, 2019 12:26 pm
by Diego2019
ok, I understand that, the parts that are outside the cylinder do not print them because they are open contours, but why does not the interior print?
Posted: Sun Mar 31, 2019 8:59 pm
by gearsawe
correction. The Stratasys Fortus systems allow this.
