Oncology Engineer
Jammed filament at start of print
Dear All,
Thanks for reading, hoping someone can help.
I have an issue that originally thought it was happening at the end of a print but might be happening from the start!
If I print something for more than 30 mins it will turn out great.
Next print the extruder blocks. This is regardless if the hotend temp remains at the same temp as previous or if it has cooled down completely.
I've attached a pic or a typical blockage as well as my g code from a recent print
Machine details;
AON M2 watercooled
Dyze Extruder with E3D Volcono nozzle 0.4 mm
Printing with ABS
Phantom 85 Block.gcode
(880.93 KiB) Downloaded 161 times
