The function is buggy,
using this option it shows a number of layers as choosen but when uncheck the button the program doesn't refresh the view. Even Exit Preview and restart it another time the partial sight to the layers is tinned.
Only check ON and than check OFF the box above to switch between Layers and Lines refreshs the screen.
horst.w wrote: ↑Thu Apr 04, 2019 2:53 pm
GER
Thank you for bringing this to our attention! We were able to test and verify this issue here in our office. For the time being simply dragging either of the sliders will reset the Preview but I will be sure to document this for the development team.
A cklick to the Preview button ends after slicing in the Preview window at the end of the g-code commands, what means all layers from 1 to end are visible.
The min-slider stands at the left (layer1) and the max-slider at the right (i.e. layer 200).
Check ON the button Show Only xxx Layers (i.e. 20 layers) cut out the layers 1 - 180 and push the min-slider to the position 180. Visible are layers 181 to 200.
Now it is possible to push the max-slider down and only the cutout of 20 layers is staying visible, i.e. layer 90 to 110.
Unchecking the box Show Only ... deactivate this partial view but does not refresh the sliders. It needs to push both buttons manually to their basic position. Thats all, but uncomfortable.
