Turn off support material nozzle when done using
Posted: Thu Apr 04, 2019 8:08 pm
by poweed
I am trying to figure out an additional terminal command to run for post-processing that will allow me to turn off tool T0's heater (M104 T0 S0) right before the very last tool change over to T1. I want to do this because the material I am using for support material (E3D Scaffold) does not really like to sit in a hot nozzle for 3 hours, and ends up becoming hard and crusty and plugging up the print head. Is there a way to accomplish this in simplify3D? Currently, I manually open the file after saving the gcode, find the second to last instance of "T1" (the last instance of T1 is when I turn off the heater for T1 at the end of the print) and insert the M104 T0 S0 line right above it.
Any help is appreciated.
Re: Turn off support material nozzle when done using
Posted: Sat Apr 06, 2019 2:48 pm
by B-H-S
cant you do this in layer / temp settings I do what you do edit the code direct but I also do the temp to 0 at a given layer ???
Posted: Mon Apr 08, 2019 1:12 am
by gearsawe
So I use the "replace"
first split the process at the point you wish to turn off
rename your process which will turn off T0 to something like "process-T0_OFF"
in the "scripts" tab under "additional terminal commands for pose processing"
add the line
{REPLACE "-T0_OFF" "-T0_OFF\nM104 T0 S0"}
so now it will replace the comment
; process Process2-T0_OFF
to
M104 T0 S0
The nice thing about this is it is Layer independent. Just split the process. add -T0_OFF to the name and that is it. just keep the replace in the scripts. I do this with pause command and don;t worry about trying to find a layer number any more. and if I change the layer height I don't have to find the new layer.
