ronaldvg
Skirt/Brim multiprocess does not function correctly
This bug has been reported before on Sat Jul 21, 2018 7:41 pm.
Problem is when I try to print make several small objects that I want to have a brim and combine that with some large objects that will get a skirt and print all processes at the same time, every object will get the brim.
It does not matter if I make process 1 or 2 the brim, they will all get the brim.
When I move the smaller objects away from the larger one (this was mentioned as a workaround), it works as expected. In the original reported bugreport it is stated that this bug was solved since 4.1 but it has not been solved. I tried 4.1.1 and 4.1.2 and both have the same problem.
Re: Skirt/Brim multiprocess does not function correctly
There were definitely improvements made here in prior releases. Please attach your factory file. I'm happy to take a look.
ronaldvg
Hi Jake,
Here you go, I just put opened some STL files and made the two processes and again they get all a brim when too close and when I move the three smaller objects away from the larger ones the processoes work as expected.
No big deal except when there is no room to move the objects away far enough.
SkirtBrim.factory
(151.62 KiB) Downloaded 33 times
