Cannot run simple .bat script via post-processing
Posted: Mon Apr 15, 2019 10:49 am
Whats the trick to getting a simple .bat file script to execute?
I'm first trying to confirm if S3D is actually running the bat file but it clearly isn't doing anything. The bat file is simple. When its run, it creates a file called "hello.log"
This is the code
echo "hello" > hello.log
In the post processing area I added:
c:\scripts\hello.bat
Nothing seems to be happening or else I'd see a file called hello.log in the output directory. This isn't the final script. I'm just testing if the bat files are executing and as of now they don't appear to be running. My real script will look something like this:
#fan.bat
python C:\scripts\pwm_postprocessor.py -o %1"_fan" %1 -S
In S3D I tried executing C:\scripts\fan.bat [output_filepath] which doesn't work.
Can anyone help me out?
This is the code
#fan.bat
