Can you control extrusion in small areas and overhangs?
Posted: Sun Aug 03, 2014 6:30 pm
I'm new to S3D and do like it. I've been using Cura, Slic3r and KissSlicer. KissSlicer by far gives me the cleanest prints I've ever made. I'm hoping that once I get used to S3D it will take the top spot.
My first test with S3d exhibits an issue on small areas and tiny overhangs. There is way too much extrusion. Is there a way to limit the extrusion to say 50% in areas that have a length threshold? For example, in the attached photos, yellow areas point to areas that are tiny circles. If I could limit the extrusion of filament on those I think the print would look better. If I could say, reduce extrusion to 50% for paths that are less than 5mm. It already looks better on the right-hand print that was done in Cura (Orange arrows). I have over extrusion in the areas with pink arrows too but overall, the Cura print looks better.
