Sliced model looks terrible.
Posted: Wed Apr 17, 2019 3:53 pm
by Duckers_McQuack
Top is what it should look like, but bottom is what it shows as. completely broken, why is that?
Re: Sliced model looks terrible.
Posted: Thu Apr 18, 2019 10:26 am
by S3D-Alex
Could you please post the STL or the Factory File? This looks like it is more than likely a model issue but I cannot confirm that without the files. You can also use Repair > Identify Non-Manifold Edges and/or Repair > Identify Self-Intersecting Surfaces to find these errant sections.
Posted: Thu Apr 18, 2019 10:58 am
See: viewtopic.php?f=9&t=13150 updated a few minutes ago!
Posted: Thu Apr 18, 2019 3:03 pm
by Duckers_McQuack
thanks, but i solved it :) Apparently the meshes were broken, and S3D can't handle such like cura can. So i imported every piece into windows 3d builder, repaired from there, then threw it in.
But this dragon won't work. Teeth no matter the layer height won't show.
Posted: Thu Apr 18, 2019 6:42 pm
by MasterFX
Link? Factory File? STL?
Posted: Fri Apr 19, 2019 4:38 am
by horst.w
Duckers_McQuack wrote: ↑Thu Apr 18, 2019 3:03 pm .... no matter the layer height won't show.
Layer Height ??? Layer Width can help perhaps!
GER
Posted: Mon Apr 22, 2019 10:46 am
by S3D-Alex
Depending on the orientation of the model here these teeth may be dipping below the thin wall threshold. I would recommend making sure you have external thin walls turned on. This option is found in the Advanced tab of the Process Settings.
