Retraction process issue with tool change script
Posted: Wed Apr 24, 2019 4:42 pm
Hello,
I had a lot of issues with the retraction during the changing tool process since the beginning of Simplify 3D. I was very happy with the new 4.1 wich the issue was fixed ! But since the 4.1.2 I have the issue again.
My trouble is that the tool changing process is impacted (outside the script) regarding if I had a script or not.
My script :
Notice, I'm using the dual extrusion to print supports.
Bellow, this is the tool changing process before printing the skirt without custom tool change script :
There is : Retraction of T0, change to T1, move to next location and G92 E0 so there is NO unretract.
Result : The nozzle is not correctly feed.
Now, the same process with a custom tool change script :
There is no retraction before the script, my script (with move to next location and unretract) but no unretract generated from Simplify 3D.
Result : Without unretract at the end of the previous tool caused oozing and a nozzle not correctly feeded too.
Yes, I could add a retraction into my script, but you will see that I have an other issue...
Now the tool changing process of each layer (just before printing the prime tower) without custom tool change script :
All is OK : retraction, changing tool, and G1 E0.2 (I set 0.2 of extra distance in settings)
Results : OK
And the same with a custom tool change script :
As previous, there is no retraction, my script, but this time, there is a unretract generated by Simplify3D, but not a G1 E0.2 as previous, but a G1 E20.2 !!!
Results : There is a very big over extrusion !
At the beginning of April with the 4.1.1 version, I was able to print well with custom script.
The Gcode before the skirt :
Custom code with a retraction generated by Simplify before the script. (no unretract, but it doesn't matter I generated it into my script)
The Code for each layer :
Every things was OK, retraction of the previous tool, my script with unretract, even the unretract generated by Simplify 3D (but this time with G1 E0 (so, there is no double unrectraction).
I hope that my English was not too bad, and you will able to help me...
PS : I have to use a custom script for 2 reasons :
1/ I unretract the T1 during my start script before printing with T0. And there is no unretraction of the T1 for the first use
2/ I delete on this exemples, but I made and extra priming process of the T1 (only) into a dirty box before to move to the next location.
My script :
{IF NEWTOOL=0} T0 ;Start tool switch 0
{IF NEWTOOL=0} G1 X[next_position_x] Y[next_position_y] F[travel_speed] ; move to next printing location
{IF NEWTOOL=0} G1 Z[next_position_z] F1002
{IF NEWTOOL=0} G1 E0 F[toolchange_retract_speed] ; prime new tool
{IF NEWTOOL=1} T1 ;Start tool switch 1
{IF NEWTOOL=1} G1 X[next_position_x] Y[next_position_y] F[travel_speed] ; move to next printing location
{IF NEWTOOL=1} G1 Z[next_position_z] F1002
{IF NEWTOOL=1} G1 E0 F[toolchange_retract_speed] ; prime new tool
G92 E0Bellow, this is the tool changing process before printing the skirt without custom tool change script :
G1 X109.975 Y103.499 E3.2314
G92 E0.0000
G1 E-20.0000 F2400
T1
G1 Z0.325 F1002
G1 X121.620 Y107.556 F12000
G1 Z0.125 F1002
G92 E0.0000
G1 X123.620 Y109.556 E0.0279 F2100Result : The nozzle is not correctly feed.
G92 E0.0000
G1 X121.620 Y107.556 F12000 ; move to next printing location
G1 Z0.125 F1002
G1 E0 F2400 ; prime new tool
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G92 E0.0000
1 X85.218 Y147.995 F2100
G1 X85.213 Y147.990
G92 E0.0000
G1 E-20.0000 F2400
T1
; feature prime pillar
G1 Z0.325 F1002
G1 X118.807 Y191.097 F12000
G1 Z0.125 F1002
G1 E0.2000 F2400
G92 E0.0000
G1 X118.807 Y200.617 E0.0940 F2100Results : OK
G1 X85.218 Y147.995 F2100
G1 X85.213 Y147.990
G92 E0.0000
G1 X118.807 Y191.097 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G1 E20.2000 F2400
G92 E0.0000
G1 X118.807 Y200.617 E0.0940 F2100Results : There is a very big over extrusion !
G1 X116.260 Y134.068 E1.2087
G92 E0.0000
G1 E-20.0000 F2400
G1 X116.094 Y134.468 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 Z0.125 F1002
G92 E0.0000
G1 X117.094 Y135.468 E0.0105 F2100The Code for each layer :
G1 X110.023 Y153.211 F2100
G92 E0.0000
G1 E-20.0000 F2400
G1 X118.769 Y160.669 F12000 ; move to next printing location
G1 Z0.125 F1002
G92 E0
T1
G1 Z0.325 F1002
G1 X111.178 Y154.196 F12000
G1 Z0.125 F1002
G1 E0.0000 F2400
G92 E0.0000
G1 X118.769 Y170.269 E0.0715 F2100
