Ret wrote:
Every single person using S3D has inaccurate print times, you're not alone.
actually that's the one thing I'm still very impressed by since v4.1.1. On different printers I have print times
on pre-heated machines within 2-3 minutes of what S3D is guessing (total print times around 2-4 hours).
I wonder if it's even possible to do this precisely unless the slicer will take care of acceleration.
It's the same for filament length... unless you update the machine config on a sailfish bot you can have
a good tuned result by tuning eSteps/gpx.ini and so on. But the number on the display will never match
the slicers calculations... (same goes for time/jerk as you already mentioned)
bye,
Daniel
