Hi,Just purchased the software and so far loving it. I just got a FF pro and this is my first 3D printer so im very new but learning fast. Right now I have everything defaulted just how the software installed it. When I go and print something the software will heat up my bed but not my Right extruder. I have to manually go into the Main control tell it to heat the extruder and then when I go to print the printer will then heat up to the correct temperature from the Gcode. Is this normal? If not how do I fix this? Thanks so much!
