Newbie question about pausing.
Posted: Thu May 09, 2019 12:47 pm
I have done a bunch of reading about this and understand the process, however, I have a question.
I can put the pause command in the "Post Processing" area just as instructed and it works. Why won't the same code work in the "Layer Change Script", or the "Tool Change Script" areas?
It seems to me that if I wanted a pause at layer 50 (for any reason at all), the "Layer Change Script" would be the place to insert it.
When I tried that, the printer went to home position at startup and just froze there. I didn't even run the "Starting Script" code.
As my name implies...ReallyObfuscated.
