nfol
Connection error
Wed May 29, 2019 4:42 am
When I click "Check for updates" or "Configuration assistant", I keep getting the message "Connection error".
Support suggests that it could be due to my firewall. However, it does not help to switch off the firewall.
My username and password is fully updated. I have no problem logging into my account from my internet browser.
I'm pretty tired of being dependent on this impossible connection. I have a lot of software that makes use of connection to the vendor, but have never encountered these kinds of problems before.
Does anyone have the same problem? Can anybody help?
Best regards,
Niels
Re: Connection error
Wed May 29, 2019 6:21 am
You might click on the network settings button and see what is listed there.
Also try going to the help menu and selecting to do a restore or return to factory settings - don't remember exactly what it is called.
Do you have anti virus or malware type programs running also?
nfol
Wed May 29, 2019 2:13 pm
I don't thing this can be otherwise. Screen clip attached.
It is called "Reset All Settings". I did that. No change.
Yes. I now tried to switch off all of that kind. No change.
S3D-Alex
Mon Jun 03, 2019 9:46 am
Could you contact us at Support@simplify3d.com if you still have issues with this? Thank you!
ratak477
Tue Jun 04, 2019 12:28 pm
I just bought Simplify 3D and I am having the same problem in macOS and a parallels version of Windows 10. Turning the firewall off isn't fixing this problem. Have you found a solution yet?
nfol
Thu Jun 13, 2019 8:14 am
ratak477:
Unfortunately not.
S3D support says that the message "Connection error" must be a Firewall issue, even it doesn't help to switch off my firewall program.
Will someone be so kind as to tell me if there is an additional firewall in Win10 itself? And how to white list simplify3D.com ?
Thu Jun 13, 2019 12:04 pm
Windows 10 does include a software firewall. This page helps walk you through using the firewall for some common functions.
https://computing.which.co.uk/hc/en-gb/ ... s-Firewall
sakunamary
Thu Jun 13, 2019 8:16 pm
I have the same problem too ,My laptop OS is MacOS 10.14.5 Mojave ,Input username and password and come out "Connection error"
I have tried to install win version in win7 VM, and the result is also not working ....
I have change IP by VPS , China\Japan VPS server not working ....
so , I thing there are some bugs in S3D. :D
greybeard
Fri Jun 14, 2019 11:13 am
In Simplify, go to:Tool> Firmware config
Set the timeout....
3D Print Parts
nfol
Sat Jun 15, 2019 5:19 am
@graybeard:
Would you be so kind as to explain a little deeper? What has firmware configuration to do with connection to the net?
Best regards,
Niels
