campo
Brim on the raft
I use raft with support material, but I want to use brim with model material to avoid warping. The problem is that the brim is not generated because is not the first layer I guess. The ooze shield can be used over the raft, but can't do a single layer to get a brim.
Any tip will be appreciated?
Re: Brim on the raft
Its not really possible to provide realistic advice without being able to see what your current settings are. Can you please attach a Factory file of a part you are having problems with. File menu====> Save Factory File.
