Pre Print Extrusion Question...
Posted: Thu Aug 07, 2014 9:22 pm
by Zekeman
I am not comparing because this software is hands down the best, but how can I change where before it prints it extrudes filament to the left of the bed, off the area. I know in makerware it extrudes to the front of the bed horizontally... can I change it to that method instead of off the bed... I am assuming its even supposed to do this....
Re: Pre Print Extrusion Question...
Posted: Fri Aug 08, 2014 9:19 am
by KeyboardWarrior
This is controlled in the starting G-code in the scripts tab. Post which printer profile you are using, and what exactly you'd like it to do, and I can mess with the starting G-code for you if you want.
Posted: Sat Aug 09, 2014 12:18 am
by BaronWilliams
Definitely spend some time learning G-code if you can.
There are some cool things you can do if you know G-code. For example, on my printer I make the lights turn red when the printer is heating up. I make them green when it's getting ready to print. I make them white when it starts printing, make them blink every time a new layer is drawn, and make them blue when the print is done. That way I can look at my printer from far off and get a good idea what's happening just by the current light color.
Posted: Mon Aug 18, 2014 4:38 pm
by Zekeman
KeyboardWarrior wrote:This is controlled in the starting G-code in the scripts tab. Post which printer profile you are using, and what exactly you'd like it to do, and I can mess with the starting G-code for you if you want.
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-120 Y-70 Z30 F9000 ; move to wait position off table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T1 ; stabilize extruder temperature
G92 A0 B0 ; zero extruders
M135 T1 ; load left extruder offsets
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-115 Y-65 Z0.15 F1200 ; slow wipe
G1 X-110 Y-60 Z0.5 F1200 ; lift
This is what I am using.. how can I enable where the test extrusion on the pre print ill go horizontally and the front of the bed?
Thanks!!
