Controlling a cooling fan in 2.1.0
Posted: Sun Aug 10, 2014 5:26 am
In my edit process settings if I go to the cooling tab and set an entry point and tell the fan to turn on at say line 2094 and at 100% should the fan come on @ line 2094 ?
I know this sounds obvious but my printer does not turn the fan ON. I am using a Wanhao Duplicator 4X with an active cooling fan mounted on the head gear. The system is fitted with a working MOSFET on the extra port, and I can manually turn the fan on from the LCD panel, so for all intense and purpose It should work.
I am also running Sailfish 7.6 Firmware, Simplify3D 2.1.0 and I am running the Mac version of the software.
T.I.A
Umpa....
T.I.A
Umpa....
