Vase mode not working for some reason specific case
Posted: Mon Jul 08, 2019 1:38 pm
I have a part that prints sloppy as its 1 perimeter.
SO I did variable to split it and did the single perm part in vase mode.
it won't do it. it ignores the vase mode command and does it in single mode which of course is sloppy.
its the processed called carriage (the part bottom right)
the top section (carriage 2) is supposed to be vase mode but its clearly showing single mode with retractions.
not sure what I am doing wrong. any suggestions?
now if I tell it to make that section solid (merge outlines) it properly does vase mode and I will try that. but I am not sure if that is going to change the part dimensionally or not.
any ideas?
Factory file attached.
any ideas?
