ANETA6 nozzle 0,6 fff
Posted: Fri Jul 12, 2019 9:22 am
by lucadraw
hi I would like to know if someone has a good setting for anet a6 with nozzle 0.6 I have weeks that I can't find a result anymore since I mounted the nozzle of 0.6
the print is not compact all the filaments seem disjointed and I don't know how to do it anymore I tried to change the settings in every way but without any result
helpppppppp :) :geek: :geek:
Re: ANETA6 nozzle 0,6 fff
Posted: Fri Jul 12, 2019 9:32 am
by wirlybird
If you can't find anything then go back to a good working setup for a 0.4 nozzle.
Then change nozzle size to 0.6 and extrusion width to 0.6 and probably slow the print speed down some depending on where it is.
Try that out on a simple test cube and see how it does. Most settings should be pretty much the same except for the ones above.
Main thing to remember is with the larger nozzle you are moving more plastic so slow a bit and maybe increase the temp a bit if needed.
