USB loosing connection?
Posted: Wed Aug 13, 2014 10:45 pm
newbie here, having trouble with my creatr.
Started a print after installing drivers for an HP laserjet, I think it might be causing trouble with the USB. I'm using a Leapfrog Creatr with Win7.
When I first started up, I was getting this:
Like I said, I just recently set up an HP laserjet 1536 on USB, I had no problems prior to that, and due to the way my computer stuff is setup right now, I'd like to keep it as a USB printer rather than messing with a router just for the printer. The creatr doesn't have an SD card slot, so it's USB or nothing. I'm looking to see if there's some way to pin down the problem sort of bothering with uninstalling the printer drivers.
Unplugging the printer USB cable and plugging it back in lets it connect, but the times I've tried printing since then it's lost the connection during the print, and can't get it back. I get this:Attempting connection at \\.\COM5...
Permissions error connecting to port
Is there another application already connected to this port?
Error opening selected port.
