First layer lump of filament
Posted: Sat Aug 16, 2014 7:13 am
by Kevink
Just installed the software form my flash forge creator dual sailfish firmware.On a windows x64 system.
When the extruder and the platform are heated up and ready for printing, the extruder squeezes out some filament on the platform without moving.
This results in a lump of melted plastic witch the extruder will drag around during printing, and worst case will get stuck in the print.
Does anyone know a setting somewhere ?
Kevin.
Re: First layer lump of filament
Posted: Sat Aug 16, 2014 11:59 am
by TenKOhms
Sounds like the purge and wipe set of commands in the starting script, which can be found under starting g-code in the scripts tab. I don't have a flashforge creator, but i just checked the gcode in the script (at least what appears in my creator dual profile) and it seems to be right?
Posted: Sun Aug 17, 2014 4:00 pm
by Kevink
Thanks for the reply.
Here is the start Gcode concerning a file causing problems:
(it happens with all the prints)
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-120 Y-70 Z30 F9000 ; move to wait position off table
M127
M140 S90 T0
M104 S230 T0
M133 T0 ; stabilize extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-115 Y-65 Z0.15 F1200 ; slow wipe
G1 X-110 Y-60 Z0.5 F1200 ; lift
I don't know much about geode, but I compared it with a replicating geode file, and it looks like what is missing is something like this:
G1 E4 F300 (Extrude 4mm of filament)
Just having a look at the geode of this post, and noticed
But the extruder doesn't move 25mm ?
Thanks, Kevin.
