Reehtorg
Print does not start
Hello i have just buyed simplify3d. i hope my settings are all correct but my Printer doesn´t print.
I Hve a Nophead Mendel90 and after these gcodes nothing happens
RECEIVED: T:29.81 E:0 B:83.0
RECEIVED: T:29.97 E:0 B:83.2
RECEIVED: T:29.97 E:0 B:83.4
RECEIVED: T:29.88 E:0 B:83.7
RECEIVED: T:29.88 E:0 B:83.8
RECEIVED: T:29.94 E:0 B:84.1
RECEIVED: T:30.00 E:0 B:84.3
RECEIVED: T:30.05 E:0 B:84.5
RECEIVED: T:30.00 E:0 B:84.7
RECEIVED: T:29.88 E:0 B:85.0
RECEIVED: ok
SENT: M105
RECEIVED: ok T:29.9 /0.0 B:85.0 /85.0 @:0%
you see the bed is heating up but after that nothing happens
Please help me :D
TenKOhms
Re: Print does not start
Could you upload a gcode file you're trying to print? Maybe someone can take a look at it
rsavell
I have a FlashForge 3D Pro and I see this all of the time, usually after I abort a print job or if a try to start a job when the printer is not at the top level menu. it usually requires that I reboot the computer and / or power cycle the printer. This is very frustrating as it can take several minutes to get it talking to the printer again and by then the extruder and the build plate have cooled off and then you need to wait for them to heat up again.
manfred59
Hello!
Same problem with my Mendel 90 printer and vers. 2.1.0 . If I then press button "force next" the printer continues to heat up the nozzle,then the bed and then it is starting the startgcode. But then the extruder produces lines with different width and collection of print material and the extruder moves forward an backwards and sometimes slipping through. I had to stop the print job.
What mistakes I have made, please help :x ? I attached the profile of my Mendel90
Manfred
Mendel90_PLA0.2.fff
(8.35 KiB) Downloaded 433 times
kloner3d
Hi, I have a kloner3d 240 and I have the same problem. It happens when I start simplify the first time, then it is all right
GoldMark
Mendel90 Nophead S3D 2.2.1 the same problem. After pressing "Force Next" it prints very well via USB.
Best Regards
Bernhard
Simplify3D 3.1 Lubuntu 16.04 LTS 364-Bit
Mendel90 Nophead with alu plate and 1mm carbon plate on top. Print only with PLA
3dp911
If you have a heated be turn it on at a low temp. It should start then. That works for me every time.
Edit: Just saw you have a heated bed. Dual extruders?
