This is the part's .stl:
http://www.fusedcreations.com/adam/barrelplug2.STL
This is the model when loaded in Simplify3d:
This is the model after slicing. What? What happened to that second hole? Why is it getting filled in?
Seems there are some missing triangles or surfaces on the part. If you do a cross section view of the object along the X-Axis then turn on the wire frame view, you can see that the left hole has an inner ring with wireframes whereass the one on the right is missing them.jamsessionein wrote:I have an object with two holes through the parts that were created the same way in 3d Studio Max. I'm amateurish at best with modelling, so I'm sure this is my fault, but I don't know how to fix it or to get Simplify3d to cooperate.
