farouk_geyoushi
PLA Bridge layer calibration
Hi all, I have a bad experience in calibrating my bridge layer parameters. I was doing bridge torture test for the second time and all results were a disaster
I'm using Anycubic Mega-S and have done bed leveling calibration once I get it and using PLA filament
I've attached the FFF profile which I used for this test and you can see below all the results
FFF profile:
bridge-torture-test_50mm (exp 2).factory
(49.16 KiB) Downloaded 127 times
Results: https://imgur.com/a/h81y2xC
Bridge 1:
Bridge Printing speed: 20 mm/s
Printing temp: 200 degrees
Bridge 2:
Bridge Printing speed: 40 mm/s
Bridge 3:
Bridge Printing speed: 60 mm/s
Bridge 4:
Printing temp: 195 degrees
Bridge 5:
Bridge 6:
Are there any tips to improve this? I thinking of stick to 195 printing temp and change the speed
Re: PLA Bridge layer calibration
Looking at your photos, one phrase sprung to mind almost straight away...." A bridge too far."
I think you need to start off with a much shorter bridge distance....a distance you do get some bridging connection across the gap.......and then compare different speeds and temperatures with that distance. Then increase the gap and compare how the different speeds and temperatures perform. Starting with what might be an impossible distance is not the way to go....
My basic starting point with bridging settings is this.
Bridging extrusion multiplier I usually set a bit lower so for PLA if I normally use 0.93 I might use 0.87 for the bridge.
I also slow to about 40% speed. These are the basics.
