Perimeter or Printthickness Issue / Need help please
Posted: Tue Aug 26, 2014 2:11 am
Dears,
I can change whatever I want - the permiterthickness is to small.
What I am wondering is that support is printed with the right thickness (see attached pictures... Zick-Zack Part is support).
My config:
Nozzle real 0,5 mm and set to 0,5 mm
Extrusion multiplier 1 - played up to 1.5
Extrusion width 0,5 mm (played up to 0,6 mm)
Layer 0,2 mm
Speed from 2000 up to 3600 mm/min
No retraction, no wipe...
Extruder perfectly validated
PLA printing at 200°C with 70° heated bed
All more or less the same failure.
Same parameters in Cura --> no issue!
Wondering which parameter in simplify3D will make the right thickness ?
Some tips for me ??
Thank you!
My config:
Layer 0,2 mm
Some tips for me ??
Thank you!
