Starting G-Code
Posted: Tue Aug 26, 2014 12:32 pm
by nbmoretto
I just installed a new custom heated build plate for my Replicator 2X which means my nozzle is right above the build plate when running the start code:
; **** Replicator 2X start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-130 Y-75 Z30 F9000 ; move to wait position off table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T0 ; stabilize extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-125 Y-70 Z0.15 F1200 ; slow wipe
G1 X-120 Y-65 Z0.5 F1200 ; lift
I was wondering if someone can help modify this script so instead of purging the nozzle in the front left the of the machine it does it in the front right and does the slow wipe towards the left instead of towards the right. Thanks!
Re: Starting G-Code
Posted: Sat Nov 29, 2014 9:44 pm
by 66tbird
I've got the same issue almost. My heated bed mod on my Rep2 (Think4D) is so long I purge a big pile and the nozzle doesn't freely move through it when done. So I skip a few steps and my prints are not centered. Another issue is the cooling fan can strike the retainer clip while on its way to start the print after the purge.
I'd like to purge 6mm above the bed then move away from the edge, raise the bed and start the print.
I'd love a few ideas on changing the start code. Even less purge would help. Is that the F300 thing?
thanks
Re: Starting G-Code
Posted: Sun Nov 30, 2014 5:27 am
by FDWorx
I would Like to do this as well......
What build plate did you purchase? Bottleworks?
Re: Starting G-Code
Posted: Sun Nov 30, 2014 9:11 am
by 66tbird
It came with the bot deal and it's a Think4D unit. I've been told I have the low amp version because it take 12 minutes to get to 65C. Times out twice trying to get to 105C. I'm not real happy with it.
Re: Starting G-Code
Posted: Sun Jan 11, 2015 12:15 pm
by paeonius
did anyone work out the solution of the big blob on the left hand side?
Re: Starting G-Code
Posted: Mon Jan 12, 2015 7:26 am
by paeonius
Re: Starting G-Code
Posted: Mon Jan 12, 2015 9:58 am
by dsegel
The F value is the speed. The G1 lines are doing the actual moves:
G1 Z0 ; move Z to 0 - leaves the head wherever it is, but lowers it to the table
G1 X-130 Y-75 Z30 F9000 ; move to wait position off table - change to positive X to have it wait on the right side I guess. I don't have a Replicator so not sure what the positioning system is.
G1 E25 F300 ; purge nozzle - this starts extruding 25mm of filament at speed 300
G1 X-125 Y-70 Z0.15 F1200 ; slow wipe - this moves to the given XYZ position (or relative depending on settings) at speed 1200. Head is raised to 0.15mm.
G1 X-120 Y-65 Z0.5 F1200 ; lift - this moves to the given XYZ position (or relative depending on settings) at speed 1200. Head is raised to 0.5mm.
To have it raise higher, change the Z value to something bigger.
If you want to purge from right to left, you need to change the start position and then change the purge movement to be right-to-left instead. The code posted looks like it does a small diagonal wipe; that's not what I've seen before, so I may be wrong about this.
Re: Starting G-Code
Posted: Fri Feb 13, 2015 9:24 pm
by 66tbird
paeonius wrote:found this discussion
https://groups.google.com/forum/#!topic ... liOwv-fIZM
Thank you
