madebyjeffrey
Trying to remove machine 3d model but it always comes back
Mon Aug 26, 2019 11:08 pm
I am doing an upgrade to my FFCP that will have it doing normal gcode communications. So as a result I have added in the FFCP through the configuration assistant and it added this model that should be of part of the machine (probably represents the bed).
I do not want this, so I went into options to remove it - tools / options / machine / printer models / remove.
Yet, when I go into edit process and press okay to close it - the model is back again.
How can I remove this thing permanently?
S3D-Alex
Re: Trying to remove machine 3d model but it always comes back
Tue Aug 27, 2019 10:05 am
The STL model the program uses is stored in the following folder on Windows C:/Users/%USERNAME%/AppData/Local/Simplify3D/S3D-Software. Please go to that folder and delete the FlashForge_CreatorPro.stl. You may need to enable hidden folders to access this directory. Please let me know if you have any other questions!
